Virtual Firewall Configuration
Answered Question
Apr 22nd, 2010
Trying to configure Virtual firewall as per the document:
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a00809492a4.shtml
Configured the vrf like this:
ip vrf acct
and  added to sub-interface
ip vrf forwarding acct
When this command is given it pops an  error:
"VRF acct not configured."  VRF acct is configured earlier.
Even after  IP inspection rule applied or  not applied same error pops up!!
Above mentioned documents states "Cisco IOS® Software Release 12.3(14)T introduced Virtual (VRF-aware)  Firewall"  I am using
ROM: 3600 Software (C3640-JK9O3S-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
Is this error due to IOS image.
Please share the experience
Subodh
Correct Answer by Giuseppe Larosa about 6 years 10 months ago
Hello Subodh,
you need at least to configure the route distinguisher under VRF config
ip vrf acct
rd 100:101
to start the VRF effectively
the document is not correct in this part rd is mandatory cannot be omitted
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 04/22/2010 - 12:26
Hello Subodh,
ip vrf acct
rd 100:101
Hope to help
Giuseppe
bapatsubodh Fri, 04/23/2010 - 08:09
Thanks Giuslar.
That Cisco document confused me a lots. I could configure overlaping private IP subnets and it's working.
Subodh
