Call Manager 6.1 - Show a Banner Msg to phone
Answered Question
Apr 22nd, 2010
I have Call Manager 6.1 and I would like to know how can I show a text banner to all of my phone for a case of an emergency... or to tell them of a service is down..
thanks
Correct Answer by foldron2002 about 6 years 7 months ago
A free workaround that you can use, is to program the Call Manager to send a message when the phone is IDLE
So when the phone is not used for an amount of time this message will kick-in (like a screen-saver)
Instructions:
How to change message to CallManager URL-IDLE
On Cisco Call Manager Adminstration :     https://CallManager-IP/ccmadmin
  • System
  • Enterprise Parameters Configuration
  • Phone URL Parameters
  • URL_IDLE                http://file-server-IP/cisco.xml
  • URL_Idle_Time        14400 seconds (4 hours)
                                          0 (default = Off)
The file cisco.xml should look like this
<CiscoIPPhoneText>
<Title>* Important message from ... *Title>
<Prompt />
<Text> Please note that ... Text>
CiscoIPPhoneText>
Stephan Ouzilleau
Overall Rating: 5 (1 ratings)
Correct Answer
foldron2002 Wed, 07/07/2010 - 18:29
Instructions:
  • System
                                          0 (default = Off)
<CiscoIPPhoneText>
<Prompt />
CiscoIPPhoneText>
Stephan Ouzilleau
