Cisco Unified Communications Express
Apr 22nd, 2010
I have a brand new router, 3825 and licensing so no worries there.  I also have some discs Cisco Unified Communications Express Products and Cisco Unified Contact Center Express/ IP IVR.
Question 1) I am trying to install CME (which I hear is now Unified Communications Express).  Do one of these disc have it on it? I have checked the flash of the router and i see no cme. I have the Adv IP Services IOS.
Question 2)  What is on those discs.
Walter Solano Mon, 04/26/2010 - 05:29
Hello Adam,
the CME is a feature that comes integrated with you IOS software, and you just need to enable it in case that you would like to configure it and work with it.
Since you have the Adv IP services IOS you should be able to use this voce feature without any issue. In the follow documments you could find first the basic configuration for a CME and CUE and the second one is the admini guide in case that you would like to see some other features.
Walter Solano
CCNA Voice
Cisco UCCX Specialist
