Hi all,
I have a consult, It´s supported the model Multisite WAN with Centralized Call Processing  used the UCMExpress???  I don´t find the model in the SRND for UCMExpress......What´s the considerations over this model?? In this model the Ip phone registration from another remote site via WAN......
Thanks for you answer
Overall Rating: 5 (1 ratings)
refram Thu, 04/22/2010 - 15:04
The model you describe is best for full Communications Manager systems.  UCMExpress is usually for a single site model.  That does not mean that you cannot register phones on UCMExpress across the WAN, it is just not recommended.  You cannot use SRST routers with UCMExpress.  So if the WAN goes down, the phones at the remote sites will be dead.
