allowing tcp and udp on 1 access list line
Apr 22nd, 2010
Hi all
can anyone tell me how to allow both tcp and udp using one access list line, I created a tcp-udp service group, I then created a tcp access list using this service group, will this work for the tcp and udp connections?
cheers
Carl
Federico Coto F... Thu, 04/22/2010 - 15:31
  • Green, 3000 points or more
You can create an Object-Group type network which includes both TCP and UDP protocols.
You can then reference an ACL to the object-group.
What exactly do you want to accomplish?
Federico.
carl_townshend Fri, 04/23/2010 - 02:32
hi there
I want to allow a protocol group with tcp and udp protocols , basically it contains, dns, http, smtp and some udp ports, then allow this outbound in an access list but using only one line
would I just create a tcp access list for this ?
Federico Coto F... Fri, 04/23/2010 - 07:31
Yes.
You can create a service object-group and specify in the object-group for TCP the protocols as well for UDP.
Then in a single ACL, reference the object-group.
Federico.
