ASDM Launcher starts in a small window
Apr 22nd, 2010
When I launch the ASDM, whether in JAVA or as an MSI installation, the window starts "too small".  I can't see anything but the minimize and close button.  (see the attached screenshot)
I am running Java v1.4.2_03.  I tried the most current release of Java and it had same results, so I uninstalled it and am back on 1.4.2_03.
...any ideas?
-Kevin
henseric1 Fri, 07/08/2011 - 16:28
Did you ever find a solution to this problem?  I am experiencing the same thing and can't figure it out.  ASDM starts in a tiny windows that I can only minimize or close.
varrao Fri, 07/08/2011 - 21:21
Hi Eric,
Kindfly provide the below information:
version of ASDM that you are running
version of ASA software
which OS are you using
Is it a 64-bit or 32-bit OS
This info would be helpful to resolve the issue.
Varun
henseric1 Fri, 07/08/2011 - 23:19
ASDM Launcher Version is 1.5(50)
ASDM Version is 6.3(5)
ASA version 8.3(2)
Windows 7
64-bit
Works fine on other Windows XP and Windows 7 - 32-bit computers I have.
varrao Fri, 07/08/2011 - 23:26
Hi Eric,
It seems to be  ajava compatibility issue, try installing the 32-bit java version on your 64-bit machine, and then try he asdm. One more thing, on the 64-bit, open up a browser and type the url "https:// (you should be able to access the asdm.
Hope this helps
Varun
Related Content
