How to Do BGP Multi homing in 2 diffrent ISP
Apr 22nd, 2010
we have two ISP they are providing internet connectivity. Now I need to do Multihoming Using BGP.
What  are require things required things
which model Router
How to use IP address :
How much will be the cost
nadeem704 Sat, 04/24/2010 - 00:28
It depend on your ISP Connection (e.g pppOe, pppOa or static ip)
If there is dialer connection then you can use router 1801
you can use thees commands
ip route 0.0.0.0 0.0.0.0 ISP1
ip route 0.0.0.0 0.0.0.0 ISP2 10
sean_evershed Sat, 04/24/2010 - 01:54
  • Gold, 750 points or more
Here is a sample conifig for mulithoming BGP.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
The routers you choose depends on your business requirements, for example how many concurrent connections the routers are expected to support.
For the cost of the routers you need to consult your local vendor.
