Problem with arhive management with SSH!
Answered Question
Apr 23rd, 2010
Hello, if someone knows how to handle it, please replay.
I have issue with arhive management in RME 4.3.0 and 2960 LANLITE switches.
It can not poll or fetch configuration from these switches or deploy with NetConfig.
Transport protocol for archive management and NetConfig is SSH. SSH on switches
is configured correctly as I can connect with normal client. I investigated about this problem,
it seems like that the problem is with SSH authentication metod. It shows me some
kinde of error for SSH : unknown authentication metod: keyboard-interactive. Here
is some output from log file :
[ Thu Apr 22  10:42:53 CEST 2010 ],ERROR,[Thread-2818],com.cisco.nm.xms.xdi.transport.cmdsvc.LogAdapter,error,19,Unknown authentication method: keyboard-interactive
[ Thu Apr 22  10:42:57 CEST 2010 ],ERROR,[Thread-2818],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchiveForDevice,1355,PRIMARY STARTUP Config fetch Failed for xxx.xxxx device
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericConfigOperator,fetchConfig,70,I am here
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericCliOperator,registerPlatform,95,Calling new GenericPlatform()
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericPlatform,<init>,23,setting GP user and pass prompts
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericPlatform,<init>,30,registering generic platform
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.xms.xdi.pkgs.SharedDcmaGeneric.transport.GenericPlatform,<init>,32,registered generic platform
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1537,Inside RMEDeviceContext's getCmdSvc ....
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1547,Protocol and Platforms passed = SSH , GEN
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1571,Iam inside ssh ....
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1573,Initial time_out : 0
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1583,Computed time_out : 36
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getCmdSvc,1599,After computing time_out : 36
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getSshCmdSvc,1637,inside getSshCmdSvc with timeout : 36000
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getSshProtocols,1743,Inside getsshprotocols with time out : 36000
[ Thu Apr 22  10:42:57 CEST 2010 ],INFO ,[Thread-2818],com.cisco.nm.rmeng.util.rmedaa.RMEDeviceContext,getSshCmdSvc,1651,SSH2 is running
[ Thu Apr 22  10:42:59 CEST 2010 ],ERROR,[Thread-2818],com.cisco.nm.xms.xdi.transport.cmdsvc.LogAdapter,error,19,Unknown authentication method: keyboard-interactive
[ Thu Apr 22  10:43:03 CEST 2010 ],ERROR,[Thread-2818],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchiveForDevice,1355,PRIMARY RUNNING Config fetch Failed for xxxx.xxxx device
Correct Answer by Joe Clarke about 7 years 2 months ago
It does not appear this device is supported by LMS yet.  What is its sysObjectID?
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 04/23/2010 - 10:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This isn't a real error.  The most likely cause is wrong credentials for the device in DCR.  Enable Archive Mgmt Service debugging undeR
RME > Admin > System Preferences > Application Log Level Settings, then re-run the Sync Archive job, and post the dcmaservice.log.
vladimirtegeltija Mon, 04/26/2010 - 01:55
Hello Joe and thanks for your time,
I checked out credentials in DCR as you said and
they are correct. Here you are some output from dcmaservice log
with debugging level on ArchiveMagement.
Write me if you find out something,
thanks in advance.
Correct Answer
Joe Clarke Mon, 04/26/2010 - 10:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
vladimirtegeltija Tue, 04/27/2010 - 04:52
Hello Joe and thanks for your time.
I checked out immediately for device support in RME as you said,
and you were right, it is not supported. I connected to cisco.com and
download new device packages for catalyst 2960. Problem solved, forks fine!
Thanks a lot and I will give you "correct answer" and few points from me
for solving my problem.
