Hairpinning and remote vpn access
Jennifer Halim Fri, 04/23/2010 - 03:48
Shouldn't be a problem.
If you have split tunnel configured, you would also need to add the vpn ip pool subnet in the split tunnel ACL.
If it's ASA firewall, then you would need to configure "same-security-traffic permit intra-interface"
Other than that, the remote access vpn should be able to access each other via the vpn assigned ip address.
Jennifer Halim Fri, 04/23/2010 - 05:34
Can't find any sample configuration on cisco.com site.
If you configure the advised configuration and it still doesn't work, feel free to post your config, and I can check out what might be missing.
