assign static ip address/user in ACS 5.1
Answered Question
Apr 23rd, 2010
In ACS 4 you have the option on a user to assign a static ip address. How do you easiest solve this in ACS 5?
Thanks in advance
/Benny
Correct Answer by jrabinow about 7 years 1 month ago
It is possible to create user defined attributes values for which can be entered as part of the user definition and then utilized in either policy conditions and/or values returned in authorization. This is a generic mechanism to meet the use case you define
This can be achieved as follows
- Define an identity attribute of type IP address
- Define users and enter their assigned IP address
- Define an authorization profile that uses the define the IP address from the user record
- Select the authorization profile as result in authorization policy
I am attaching some slides that illustrate this process
Overall Rating: 5 (1 ratings)
Correct Answer
jrabinow Fri, 04/23/2010 - 03:30
  • Cisco Employee,
bein Fri, 04/23/2010 - 04:38
Thanks for the help. It would be interesting to see the slides you mention, so if you have time could you pls upload again because they are missing.
/Benny
jrabinow Fri, 04/23/2010 - 06:15
  • Cisco Employee,
retry the attachment (an an allowed format this time I hope)
