asa5520 issue with memory utilisation
Apr 23rd, 2010
I have two Cisco ASA 5520 firewalls (Active/Standby) running with software version 8.2(1)11 version
I have encountered a problem while saving the  configuration . The memory utilisation is hig 84%
So, I have issued some commands to see the memory utilization on firewalls.
the output was
as follows
show mem
ASA# sh memory
Free memory:        91015464 bytes (17%)
Used memory:       445855448 bytes (83%)
ASA# sh mem detail
Free memory:                      91180528 bytes (17%)
Used memory:
     Allocated memory in use:    338113040 bytes (63%)
     Reserved memory:            107577344 bytes (20%)
Total memory:                    536870912 bytes (100%)
  Finally i disable  run threat-detection to free some memory but after the reboot has the same memory utilisation .
What the reserved memory in Sh Memory detail output means
Is upgrade of memory the only solution in this situation or any other workaround possible (like clearing threat-detection)
Which oS should i upgrade as i can see many ceveats open with current version and memory is also one of them
Jennifer Halim Fri, 04/23/2010 - 06:47
  • Cisco Employee,
Yes, you are right. There are a number of memory related bugs in 8.2.1.
I would suggest that you upgrade the ASA to version 8.2.2.
