Can I not do GRE through the UC540?
bjames
Level 5
Level 5
I don't see too many options in the NAT setup for the UC540. The client still wants GRE/PPTP through to their server (until we switch them to VPN), I can setup the TCP port but can I add the GRE protocol?
Bob
bjames
Level 5
Level 5
.....tumbleweed...............Cisco?
Let me add another question, can I do NAT transversal or at least change from stock UDP based VPN to TCP based VPN?
Hi Bob,
This can be done in IOS, but using CLI, not CCA.
Marcos
Yes but will CCA still work after the ACL mod?
Bob
You should be able to use CCA for phone stuff, but don't even try to use it for a CLI modified VPN...
