CDP enabled on access ports (On a trunking port)
Joe Clarke Fri, 04/23/2010 - 12:17
What version of Campus Manager do you have?  It could be that Data Collection is not properly completing, and thus not detecting that these are trunk ports.
Joe Clarke Sun, 04/25/2010 - 09:41
RME has nothing to do with the Campus topology.  I think you're seeing a known bug.  Upgrade to Campus Manager 5.1.4 from Common Services > Software Center > Software Update.  Then run a new Data Collection, and this BPD should disappear.
Sean Gilkes Thu, 11/25/2010 - 00:20
Hi Joseph,
We are running Campus Manager 5.2.1 and we're seeing exactly the same issue.  Is there anything I could try doing before opening a TAC case..?  Also you mentioned that this was a reported bug in version 5.1, but I could not find any bug listing in the Bug Toolkit; would you know the bug ID..?
Joe Clarke Thu, 11/25/2010 - 19:57
Please start a new thread for your issue, and post the ani.log when you do.
