Share DN between 3rd Party SIP and SCCP - CME
Answered Question
Apr 23rd, 2010
I am using SIPDroid on my Droid to connect to our CME.
I'd like for calls to my extension, 168, to ring both my SCCP desk phone and the SIP client on my Droid. Can this be done?
I've been able to register my SIP client to CME successfully on an differnet DN. I used CFNA to get calls forwarded to my Droid, but I'd rather just have both ring simultaneously like an overlay.
Cheers.
Correct Answer by paolo bevilacqua about 7 years 2 months ago
Decide a number to ring both. Configure it as voice hunt pilot. There is no better way.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Fri, 04/23/2010 - 09:09
  • Hall of Fame,
    Founding Member
b.gamble Wed, 05/05/2010 - 04:03
This solution worked well until someone tried to forward a call to my main number, the hunt pilot.
Main DN/hunt pilot: 168
hunt group list: 268,368
Anyway for them to be able to transfer to my well-known main dn of 168 rather than one of the other two DN's?
David Hailey Wed, 05/05/2010 - 07:53
  • Purple, 4500 points or more
Unfortunately, if your primary line is set up as a hunt pilot - then anytime you forward to that extension (the hunt pilot), it will invoke the hunt behavior of the line groups which is to hunt the other 2 extensions. This is basic, expected behavior.
Hailey
Please rate helpful posts!
b.gamble Wed, 05/05/2010 - 07:55
It actually rings busy.
Thought maybe there was a work around.
David Hailey Wed, 05/05/2010 - 08:08
So, I'm coming in a little late here and I deal mostly with Enterprise deployments so I don't do a lot of testing on CME - but I'd to ask:  Did you attempt to configure your SIP device with a shared DN (SCCP) phone and see if it will register?  This can easily be done on CUCM so again, I'm asking to see if we can find a better solution.
Secondly, when you forward a call to the hunt pilot - are the two members of the line group registered when you get a fast busy?
Hailey
paolo bevilacqua Wed, 05/05/2010 - 08:56
  • Hall of Fame,
    Founding Member
If you register a SIP phone with the same number as an SCCP phone, or two SIP one, or two SCCP ones, it will ring only the one with better preference (can't remember which one right now), and if preference is set equal, will ring them round-robin.
b.gamble Wed, 05/05/2010 - 09:25
Keep in mind the SIP phone is a 3rd party SIP client.
I initially had the SIP phone sharing the DN with my deskphone (SCCP).
I can't remember what exactly didn't work as it's been a few weeks since I tried it, but I'll try it again and see.
paolo bevilacqua Wed, 05/05/2010 - 09:30
  • Hall of Fame,
    Founding Member
It is not a matter of phone being third-party or not, but it being SIP.
You cannot share DNs between SIP and SCCP, and I think this limitation will stay for a very long time.
If you want seamless, feature-rich and robust working, get all Cisco SCCP phones.
b.gamble Wed, 05/05/2010 - 09:32
I will gladly do that as soon as Cisco has a client for Android.
Until then I'll search for weird work arounds to get the functionality I want.
paolo bevilacqua Wed, 05/05/2010 - 10:36
  • Hall of Fame,
    Founding Member
CF to hunt pilot should work, it may be a configuration issue, and one should look at it and to traces.
David Hailey Wed, 05/05/2010 - 09:25
Sounds like a limitation with CME then and unfortunately, the hunt pilot / line group is going to have drawbacks too.
Hailey
eoinwhite Fri, 05/07/2010 - 04:17
Can someone tell me how to get SIP Droid to register with th call manager. I was able to do this using SIP on a Nokia E51 but im struggling to do it with my HTC.
TIA.
paolo bevilacqua Fri, 05/07/2010 - 04:23
  • Hall of Fame,
    Founding Member
Please open a new thread for a new problem.
David Hailey Fri, 05/07/2010 - 04:34
You mean CUCM and not CCME? Is SIP Droid a client younrun on the
phone? If yes, I'll forward a blog to you for how CUCM wants SIP
clients configured.
Sent from my iPhone
On May 7, 2010, at 7:17 AM, eoinwhite
Related Content
