Why Won't This Trunk Come Up, Part 2
Apr 23rd, 2010
Just wanted to bring back this discussion on manually setting the trunk parameters on two sides of a trunk and why it doesn't work.
The first time I did it was between two 3560s, and it didn't work.
Then I tried between a 3500XL and a 2960, and it didn't work.
Then I tried it today between a 2950 and a 2960, and it doesn't work.
1. Settings on each side:
Mode: Trunk
Speed: 100
Duplex: Full
(This config doesn't work)
2. Settings on one side:
Mode: Trunk
Speed: 100
Duplex: Full
2a. Other side:
Mode: Trunk
Speed: Auto
Duplex Auto
(Results in duplex mismatch errors.)
3. Settings on both sides:
Mode: Trunk
Speed: Auto
Duplex: Auto
(This works, negotiates full duplex and 100Mbps ethernet)
Any ideas on why manually setting trunk parameters on each side, effectively disabling DTP, doesn't work?
Overall Rating: 5 (1 ratings)
Jon Marshall Sun, 04/25/2010 - 14:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nelson
I suspect this is to do with which cable you are using ie. cross-over or straight-thru and whether auto-mdix is enabled or not. I remembered reading about this a while back and have finally found the link i was looking for -
http://cciepursuit.wordpress.com/2007/07/08/switch-cabling-and-auto-mdix/
Jon
nelson.garcia Mon, 04/26/2010 - 11:10
Jon, this looks exactly like what I need. I never really did use crossover cables for anything, figured you could use straight through cables for everything these days. I might also add that i tried trunking two 2950s with a default port config together and the link wouldn't come up, so I tried a trunk between a 2950 and a 2960 and it DID work. My guess is that the older 2950s just need a crossover cable because they might not have MDIX like the 2960 may?
Thanks for the link, Jon. I'll let you know if this works.
Jon Marshall Mon, 04/26/2010 - 11:25
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Nelson
Funny that because i do the opposite ie. i always use crossover cables but i think that means i'm a bit oldfashioned
Jon
Please rate helpful posts
