PIX IPSec and ACL Questions
Answered Question
Apr 23rd, 2010
On a PIX 515E v.6.3.5.
Are there three ACL lists that can come in to play when configuring an IPSec VPN on a PIX? (I hear a roar of "It depends" )
1. Nat (0) ACL  - to NOT nat traffic this is part of the IPSec VPN
2. Crypto ACL - ACL that distinguishes if the traffic is destined for the IPSec tunnel.
3. ACL - ACL to permit | deny traffic after ACL #1 and #2.
Does #3 "enable IPSec packets to bypass access list blocking" if the "sysopt connection permit-ipsec" command is configured, and ONLY on ACL #3? In other words the sysopt doesn't participate on ACL #1 or 2 listed above?
The mirroring of ACL's, that is suggested (required) for both sides of the IPSec tunnel applies to which ACL?
Dan
Correct Answer by Jon Marshall about 7 years 2 months ago
Dan
Dan
It depends
1) Not always used because with a site-to-site VPN sometimes you have to NAT your internal addressing
2) always needed
3) if "sysopt connection permit-ipsec" is configured any acl on the interface where the VPN is terminated is bypassed. If it isn't enabled then once packets are decrypted they are then checked against the acl.
Mirroring of acls is required.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 04/23/2010 - 13:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dan
Dan
It depends
2) always needed
Jon
pdvcisco Fri, 04/23/2010 - 13:37
Jon,
Thanks, that get me mostly there.  For the last question. Which ACL "must" be mirrored, it is inferred by your answer, only the second ACL must be mirrored, and only that one matters to the actual IPSec VPN - the VPN doesn't even know of the other ACL's, correct?
Dan
Jon Marshall Fri, 04/23/2010 - 13:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dan
Correct, only crypto acls need to mirror each other  because it this acl that is used to determine what the peers think are the remote and local subnets.
Jon
pdvcisco Fri, 04/23/2010 - 15:07
Thanks Jon! That was just what I needed, perfect.
Related Content
