Unity Connection Cluster - DNS resolution
Apr 23rd, 2010
It is posible to remove DNS resolution in a cluster AFTER the cluster is set (AKA: both unity Connection were installed using DNS resolution)?
Version 7.1
David Hailey Fri, 04/23/2010 - 16:48
  • Purple, 4500 points or more
The installation rules for DNS are that if you do not configure it on initial install, then you cannot enable it post-installation without rebuilding the system.  My inclination is that the reverse is also true.  I also tested trying to remove the DNS configurations on a 7.1(3b)SU1 CUC server in my lab and there doesn't appear to be a valid command to do this.  You can change the primary and secondary DNS servers; however, you cannot disable DNS.
Hailey
Please rate helpful posts!
aalejo Fri, 04/23/2010 - 18:33
If you take out the DNS server(s)s you will disable DNS resolution.
- Alex
David Hailey Fri, 04/23/2010 - 18:38
Alex,
Have you attempted to do this on a 7.1 server? If you attempt to set a blank DNS server, you get a CLI error for a missing, required configuration parameter...at least I did.
Hailey
aalejo Fri, 04/23/2010 - 18:39
There is a command for clear DNS server.
- Alex
