node name , is not part of the cluster CRS
Apr 23rd, 2010
Trying to get access where the scripts are, I´m getting the following error "nodename" is not part of the cluster CRS , attached is the screenshot I gathered. Any help on this will be highly appreciated.
David Hailey Sat, 04/24/2010 - 06:17
  • Purple, 4500 points or more
Did you configure a local hosts file - this would be in Windows\System32\Drivers\Etc folder path.  Should contain the local name resolution of cluster hosts to IP.  May not be the total issue - but worth taking a look.
Hailey
Please rate helpful posts!
