ACS 5.1 install on VMWare Workstation
Apr 24th, 2010
  • Bronze, 100 points or more
Trying to install ACS 5.1 on VMWare Workstation 6.5 getting acs traceback kickstart error, originally setup a SCSI 650GB drive which CentOS didn't recognize, changed drive to IDE but getting different error now.
speciified disk sda in partition command which does not exist
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_vmware.html
Overall Rating: 5 (2 ratings)
Jason Aarons Sun, 04/25/2010 - 08:53
Made it a 80DB IDE (vs SCSI) virtual disk and get past it detecting 0GB for disk space during setup.
However then i get a Traceback :kickstart.KickstartValueError: specified disk sda in partition command which does not exist
Cristian Venegas Mon, 05/17/2010 - 23:32
  • Cisco Employee,
Jason,
I just ran into the same issue you're experiencing. After playing around, i found out that when creating the VM, if you choose the SCSI disk (with > 60GB capacity, no need to allocate space) and the LSI Logic adaptor (not Buslogic!) it works perfectly.
Cristian Venegas
Channel Systems Engineer
Cisco Chile
Related Content
