How to secure my ASA5505
Answered Question
Apr 24th, 2010
I am very basic knowledge of ASA5505 and I recently purchase one for home usage.
I need assistance in hardening this ASA.
Below is my current config, please advise suggestions to lock it down.
Also, I am having trouble entering for the following command via CLi, it won't accept the command "class inspection_default":
policy-map global_policy
inspect dns preset_dns_map
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
thx
ASA Version 8.3(1)
hostname xxxxx
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxx encrypted
names
interface Vlan200
 nameif outside
 security-level 0
 ip address dhcp setroute
interface Vlan500
 no forward interface Vlan800
 nameif dmz
 security-level 50
 ip address 10.2.1.1 255.255.255.0
interface Vlan800
 nameif inside
 security-level 100
interface Ethernet0/0
 switchport access vlan 200
interface Ethernet0/1
 switchport access vlan 800
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
 switchport access vlan 500
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone xxxxxxx
object network obj_any
 subnet 0.0.0.0 0.0.0.0
access-list outside_access_in extended deny ip any any
access-list dmz_access_in extended deny ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu dmz 1500
mtu inside 1500
ipv6 access-list inside_access_ipv6_in deny ip any any
ipv6 access-list dmz_access_ipv6_in deny ip any any
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
 nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
access-group dmz_access_ipv6_in in interface dmz
access-group inside_access_ipv6_in in interface inside
route outside 0.0.0.0 0.0.0.0 [ISP default gateway] 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
console timeout 5
dhcpd auto_config outside
dhcpd address 192.168.1.8-192.168.1.10 inside
dhcpd dns [ISP DNS1] [ISP DNS2] interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username mmok password xxxxxxxxxxx encrypted
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map gloabl_policy
service-policy global_policy global
prompt hostname context
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxx
: end
Correct Answer by Federico Coto F... about 7 years 1 month ago
The policy-map global_policy which contains the class inspection_default are by default part of the configuration of the ASA.
This policy-map is linked globally to the ASA with the service-policy global-policy command.
Check out more information here:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/inspect_overview.html
Let us know if you have any questions.
Federico.
Overall Rating: 5 (1 ratings)
Federico Coto F... Sat, 04/24/2010 - 09:03
  • Green, 3000 points or more
It seems the ASA has 3 interfaces (inside, dmz, outside)
All incoming traffic through the outside and dmz interfaces is denied by ACLs.
Outgoing traffic is permitted.
It seems to be ok, the recommendations will be depending on what do you want this ASA to do.
Do you currently have Internet access from your home through the ASA?
Federico.
SPERTWCISCO Sat, 04/24/2010 - 09:12
Outside is current connected to my ISP.
Inside contain one laptop.
Nothing in DMZ so far.
I have good handle with access-list (I think), but I am more worry about the inspection policy, etc...  which I am not familiar with and hope I can get some help on it.
thx
Correct Answer
Federico Coto F... Sat, 04/24/2010 - 09:20
Federico.
SPERTWCISCO Sat, 04/24/2010 - 19:19
The document looks good! I will have to read on it! thx
