How to check trunk port on 3548 xl switch
Answered Question
Apr 24th, 2010
Hi all,
i have 3548 xl switch  i know on other switches i can use command
sh int trunk  but on this switch it  does not work.
do anyone knows which command we can use  to check trunk ports other then this
sh int fa switchport???????????
thanks
mahesh
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Mahesh,
usually this kind of switches support the command
show interface typex/y switchport
the output of this command can provide a lot of information
You should look for the lines containing the following words
admin state = configured state
operation state = current state
this show can tell if a port is acting as a trunk or not and other info
Hope  to help
Giuseppe
Correct Answer by Jon Marshall about 7 years 3 months ago
mahesh18 wrote:
Hi all,
thanks
mahesh
Mahesh
Unfortunatley on the XL switches there is no equivalent command to "sh int trunk". Best you can do is save config to a text file and do a search for "trunk".
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sat, 04/24/2010 - 14:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mahesh18 wrote:
Hi all,
thanks
mahesh
Mahesh
Jon
Correct Answer
Giuseppe Larosa Sat, 04/24/2010 - 14:33
  • Hall of Fame,
    Founding Member
Hello Mahesh,
Hope  to help
Giuseppe
