VOIP external to SA540
Apr 24th, 2010
I have an SA 540, I also have internal to the network a VOIP enabled phone system.  I have NAT rules on this box pointing a public address to the private LAN address on this box.  For troubleshooting purposes I have all ports open to the VOIP phone system from this external address.  I receive no audio with my external phones, but the phones do register with the phones system.  I do have the SIP ALG enabled,  I do not have any of the extra features with this box.  The PBX is an Samsung Officeserv 7200.
If any has any ideas I would greatly appericate it.
Rex
hyeh Mon, 04/26/2010 - 10:54
We used to have a similar bug filed against 1.1.21 firmware
And it has been fixed in 1.1.42
If you are not using 1.1.42, can you please try this firmware first
We appologize for the inconvenience
Henry
jasper1981 Mon, 04/26/2010 - 11:30
I am using 1.1.42 firmware...
Any other information you need?
Thanks,  As I sitll have this issue.
Rex
hyeh Mon, 04/26/2010 - 12:07
Hi Rex
Can you provide us the packets log by using "Administration->Diagnostics->Router Options->Capture Packets" while making the phone call
weilia Mon, 04/26/2010 - 14:39
  • Cisco Employee,
Hi Rex,
Please also send us your SA540 Configuration file.
thanks
Wei
Related Content
