loose source route option in ip header
Answered Question
Apr 24th, 2010
  • Bronze, 100 points or more
Hi everybody.
I am trying to understand   the  option " loose source route option" in the ip header. I got the general idea how it is used,  but i am looking for a link  that can illustrate  its usage.  if anyone knows  such link, please forward to me. I did try to google it but did not come with any link illustrating the concept.
thanks and have a good day.
Correct Answer by Reza Sharifi about 7 years 3 months ago
Hi Sara,
From RFC 791 (internet protocol)
The loose source and record route (LSRR) option provides a means
        for the source of an internet datagram to supply routing
        information to be used by the gateways in forwarding the
        datagram to the destination, and to record the route
        information.
        The option begins with the option type code.  The second octet
        is the option length which includes the option type code and the
        length octet, the pointer octet, and length-3 octets of route
        data.  The third octet is the pointer into the route data
        indicating the octet which begins the next source address to be
        processed.  The pointer is relative to this option, and the
        smallest legal value for the pointer is 4
Also here is a link to the RFC
http://www.networksorcery.com/enp/rfc/rfc791.txt
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Sat, 04/24/2010 - 20:13
  • Cisco Designated VIP,
    2017 LAN
Hi Sara,
        information.
Reza
