IPCC PROMPT VOLUME
Apr 25th, 2010
I'm currently using IPCC Express 7.0(1) Enhanced version.
I've noticed that when uploading prompts and play them through any application their volume is reduced. Is there a way within the IPCC where we can increase the volume of the prompts just a little bit?
Thank you
Zaid
Overall Rating: 4 (1 ratings)
AHMED Ali Sun, 04/25/2010 - 17:17
Hello Zaid,
There is no parameter in UCCX doing this as far as I know, you have to use WAV editor program & modify your WAVs then upload it again.
Ahmed Rizk
