7609 to 3550 connectivity
Apr 25th, 2010
Dear all,
  i m trying to connect 7609 Router to 3550 Sitch at one of thier fastethernet
on 7609 , interface been configured with ip 10.99.16.2 /29,
but couldnt configure  ip on 3550 side , what is to be done on switch end
also permitted the switch network which is 10.97.112.0 in ospf ,bgp routemap ACL on 7609
attached the switch config
Reza Sharifi Sun, 04/25/2010 - 08:16
  • Cisco Designated VIP,
    2017 LAN
Hi anandkumar,
Not clear what you are trying to do but
If you want to assign on IP to the port without using a vlan (a layer 3 routed port) then you need to enter no switchport under interface configuration command and than assign an IP to it.
Reza
