Access Point IP Ratings?
Apr 25th, 2010
Cisco are regularly quoted as saying Aironet 1240/1250 series AP's are designed for challenging environments. What I want to know is what are the 1240/1250 series AP's IP ratings. Anyone?
Overall Rating: 5 (1 ratings)
Leo Laohoo Mon, 04/26/2010 - 19:37
"challenging environments" means the physical environment.  The 1240/1250 as you can tell is built around an all-metal chassis to protect itself from the environment.  Sure it's not water proof or water resistant but it was designed to be sturdy.  This family of APs are designed for industrial use and designed to be deployed in wide open spaces such as theatres/cinemas, warehouse, hangars, etc.
andrew-mccabe Thu, 07/15/2010 - 02:18
"challenging" is ambiguous in context but to not publish/disclose the ratings required in order to completely design a solution fit-for-purpose puts Cisco at a disadvantage. To state that for example a 1240 is designed for warehouses, theatres etc is a little simplistic and we nor Cisco cannot contain the industry verticals in which to operate, again a disadvantage to Cisco.
Designing a solutioin for a vitreous manufacturing plant for example, where fine dust and water dictates the solution, you would want to know that the equipment you are investing in can cope with the environmental challenges in which it is dealt.
Anyway, I have done some digging and come up with the following. I believe this to be as accurate as can be.
Antenna ratings are not published but environmental controls can be viewed on the datasheets.
Vinay Sharma Sun, 05/29/2011 - 07:33
Please mark the Question as Answered if the provided information is correct and issue is fixed.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
