IPv6 Unicast Address
Answered Question
Apr 25th, 2010
The answer for the question below is 3.
Why can't 4 be a valid unicast address?
Which address is a valid IPv6 unicast address?
1.    FE90::1::FFFF
2.    FD80::1::1234
3.    FE80::1:4545:6578:ABC1
4.    FEA0::100::7788:998F
5.    FC90::::5678:4251:FFFF
Correct Answer by mlund about 7 years 2 months ago
Taken the same example as Ganesh.
2001:cdba:0000:0000:0000:0000:3257:9652
2001:cdba:0:0:0:0:3257:9652
2001:cdba::3257:9652
this example shows how You can group a set of zeroe's together and write it as :: instead.
However this double :: can only be present once, so an address written as
2001:cdba:0:0:1:0:0:9652 can be written either as
2001:cdba:0:0:1::9652 or
2001:cdba::1:0:0:9652 but not
2001:cdba::1::9652
In question 1,2 and 4 there are two groups of :: , this is not valid, and in q5 it's written ::::, wich is also not a legal address.
/Mikael
Overall Rating: 5 (5 ratings)
Ganesh Hariharan Sun, 04/25/2010 - 23:09
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
1.    FE90::1::FFFF
2.    FD80::1::1234
Answers 3 is correct is because fe80::/10  is a link-local prefix offered by IPv6. This address prefix signifies that the address is valid only in the local physical link.An IPV6  Unicast address acts as an identifier for a single interface. An IPv6 packet sent to a Unicast address is delivered to the interface identified by that address.IPv6 addresses are denoted by eight groups of hexadecimal quartets separated by colons in between them.
Following is an example of a valid IPv6 address: 2001:cdba:0000:0000:0000:0000:3257:9652
Any four-digit group of zeroes within an IPv6 address may be reduced to a single zero or altogether omitted. Therefore, the following IPv6 addresses are similar and equally valid:
Network Notation in IPV6 follows the below example
2001:cdba:9abc:5678::/64 denotes the network address 2001:cdba:9abc:5678. This network comprises of addresses rearranging from 2001:cdba:9abc:5678:: up to 2001:cdba:9abc:5678:ffff:ffff:ffff:ffff. In a similar fashion, a single host may be denoted as a network with a 128-bit prefix. In this way, IPv6 allows a network to comprise of a single host and above.
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
leepeiwai Mon, 04/26/2010 - 01:48
Ganesh, Thanks for your reply.
However, my question is why 4.(FEA0::100::7788:998F) is not a valid unicast IPv6?
I read that IPv6 private addresses begin with FE, and follow with 8 to F.
Therefore, all 1,3,4 can be unicast address?
1.    FE90::1::FFFF
2.    FD80::1::1234
Ganesh Hariharan Mon, 04/26/2010 - 02:55
1.    FE90::1::FFFF
2.    FD80::1::1234
A link-local unicast address has the prefix fe80::/10 in standard IPv6 addressing scehme and following are the cases with meaning of address used
2001:db8::/32 This is a documentation prefix allowed in the IPv6. All the examples of IPv6 addresses should ideally use this prefix to indicate that it is an example.
fec0::/10 This is a site-local prefix offered by IPv6. This address prefix signifies that the address is valid only within the local organization. Subsequently, the usage of this prefix has been discouraged by the RFC.
fc00::/7 This is called the Unique Local Address (ULA). These addresses are routed only within a set of cooperating sites. These were introduced in the IPv6 to replace the site-local addresses. These addresses also provide a 40-bit pseudorandom number that reduces the risk of address conflicts.
ff00::/8 This prefix is offered by IPv6 to denote the multicast addresses. Any address carrying this prefix is automatically understood to be a multicast address.
fe80::/10 This is a link-local prefix offered by IPv6. This address prefix signifies that the address is valid only in the local physical link.
Check out the below link for address scehme
http://www.6diss.org/workshops/saf/addressing.pdf
Hope to help !!
Ganesh.H
Correct Answer
mlund Mon, 04/26/2010 - 04:34
  • Silver, 250 points or more
2001:cdba::1::9652
/Mikael
leepeiwai Mon, 04/26/2010 - 14:42
Thanks Ganesh and Mikael for your explaination.
