connectivity issue between 2 servers connected to 2 different switches
Apr 25th, 2010
Hi All,
we have  two switches connected via a trunk link that is configured as below::
interface FastEthernet0/23
description Connection to SWITCH-1
switchport trunk allowed vlan 4094
switchport mode trunk
switchport nonegotiate
description Connection to SWITCH2
2 hosts that belong to VLAN 4094 are attached to each switch as per the network diagram. sometimes these servers are not able to communicate with each other. The ARP table on the servers is missing the other host entry.
any clue?
is there anything wrong with the configuration?
Switch1:
interface FastEthernet0/5
switchport access vlan 4094
switchport mode access
no cdp enable
spanning-tree portfast
Switch2:
interface FastEthernet0/3
no cdp enable
thanks
Jean
lamav Sun, 04/25/2010 - 08:46
  • Blue, 1500 points or more
Jean, there is nothing wrong with your configuration. Is there any part of the configuration that you have not posted that may effect the PINGs?
If not, what you need to do now is ensure the integrity of all the connections. Make sure no port is bouncing or taking errors. Verify the trunk's integrity.
Let's take it from there.
vishwancc Sun, 04/25/2010 - 21:54
Hi Jean,
1.Do you see mac table entry in the switches when the issue occur.
2.Do you see arp entry.
3.I have your network is stable and no spanning tree issue.
4.You mention the server loose connectivity between each other,have you checked pinging the server from different Pc i the Valn does that Pc also loose the connectivity.
Since you are loosing the connectivity to only specific mac we have to do these test in order to verfiy where the issue is.
Chao
Vishwa
