HOW TO INTEGRATE NAC TO LDAP?
Answered Question
Apr 25th, 2010
Hello
I am integrating my NAC  to LDAP, I added the LDAP using simple authentication but when I log in a user from LDAP. It does not authenticate. I followed the procedure from cisco,(Add LDAP to Authentication server using simple authentication). What are the other procedures after I add the LDAP to the authentication server list?
thank you and best regards,
Correct Answer by Faisal Sehbai about 6 years 10 months ago
You then have to enable the Auth provider in your login pages. Click on User Pages -> Edit -> Content and make sure the LDAP provider you've defined is checkmarked here.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Mon, 04/26/2010 - 18:51
HTH,
Faisal
ericohermoso Mon, 04/26/2010 - 23:14
Hello Mr Faisal,
Thanks I already, Integrate using LDAP and its working fine.
Edwin
