Im lost! Several attempts to connect 2 cable modems onto the RV042 .One is directly connected to the modem the other is conected to a linksy fast ethernet im trying to accomplish load balancing with no luck i can only get one at a time to
Apr 25th, 2010
Header 1Header 2
cchamorr Mon, 04/26/2010 - 11:50
  • Silver, 250 points or more
First of all, I really couldn't understand your configuration, but here is what you need to do:
1st- make sure you get internet of both cable connections
2nd- Connect each modem to wan ports on the back of the router (There are two of them)
3rd- Set the router for load balancing under system management
4th- reboot the router and it should be working.
Hope this helps!
