Maximum bandwidth supported on the FE interface for WAN link -1841
Answered Question
Apr 26th, 2010
We have an 1841 router with a serial link of 2Mbps for internet leased line.
Now we are upgrading the internet bandwidth to 12 Mbps. The service provider is giving it on FastEthernet interface.
Can i use the same router for the purpose???
What is the maximum WAN bandwidth supported by 1841?? Where (or How) can we find the bandwidth limitation (or backplane capacity) of a particular series of router?? Thanks for any guidance....
1 vote
Correct Answer by shailesh.h about 6 years 8 months ago
Router sizing document attached showing clearly that you can go ahead with 1841 with proposed 12Mbps WAN link
With regards,
Shailesh
Correct Answer by csawest.dc about 6 years 9 months ago
Dear Friend,
Cisco 1841 Router FE Maximum Bandwidth Support up to 38 MB
Cheers!!!
Vaib,..
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Maximum throughput on an 1841 is 38.40Mbps, thats with no acls, basically nothing running on it of IP routing.check out the below link  for more info:-
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_qas0900aecd80181208.html
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Overall Rating: 5 (3 ratings)
Correct Answer
Ganesh Hariharan Mon, 04/26/2010 - 00:50
Hope to Help !!
Ganesh.H
Correct Answer
csawest.dc Mon, 04/26/2010 - 04:28
Dear Friend,
Cheers!!!
Vaib,..
mohdniyas Tue, 04/27/2010 - 07:49
Thanks for ur response...
But i couldnot find in the link provided by u,  that 1841 has a Maximum throughput of 38 Mbps???
Instead it says up to "single T1/E1/xDSL speeds"!!!
Q. What is the performance of the Cisco 1841?
A. The Cisco 1841 is a new-generation, best-in-class router platform  designed to deliver multiple concurrent services at wire-speed  performance up to single T1/E1/xDSL speeds. Chassis performance has been  increased up to five-fold, and security performance increased up to  seven-fold compared to the Cisco 1700 Series. The single T1/E1/xDSL  value quoted here represents IMIX packet sizes in higher-than-typical  Cisco 1841 services configurations. In less service-heavy environments,  actual WAN throughput
will be higher.
Can u pls clarify...
Correct Answer
shailesh.h Mon, 04/26/2010 - 10:22
With regards,
Shailesh
