No docs on command "rollback filter adaptive"
Apr 26th, 2010
I'm working on configuration archiving and have stumbled across what seems to be an undocumented command in 12.4(25c).  In particular I am using a 2851 but would assume the command exists in other architectures and the T train as well.
Under the "archive" subcommands there is an option to enable "rollback filter adaptive."  I have been in the IOS docs, including the master list, and even the command lookup tool.  The description given interactively is "Enable adaptive learning for rollback" but I have no idea what effect that really has on rolling back to an archived config.
Has anyone used this or know what this is used for?
Tyler West, CCNP
Sr. Network Engineer
CWI, Inc.
