cannot telnet to standby asa
Apr 26th, 2010
Hi all
Is there any reason why I wouldnt be able to telnet to my standby asa? I can ping it from the other ASA fine,via the lan interface, but I cannot ping it from other subnets, should I be able to get to both firewalls for management in the active/standby config ?
cheers
Carl
Jennifer Halim Mon, 04/26/2010 - 04:25
  • Cisco Employee,
Yes, you should be able to telnet to the standby ASA.
What does "show failover" show? Where are you trying to telnet to the standby ASA from?
carl_townshend Mon, 04/26/2010 - 05:05
Hi There
it appearred to be a routing issue, the firewalls were using eigrp to the next hop, I install a static route on them and this fixed the issue.
Carl
Maykol Rojas Mon, 04/26/2010 - 10:39
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Hello Carl
You are right, and just to backup your answer, here is the information about stateful failover, it says that no routing table information will be passed to the secondary unit,
The information that is not passed to the standby unit when stateful       failover is enabled includes these:
  • The HTTP connection table (unless HTTP replication is           enabled)
  • The user authentication (uauth) table
  • The routing tables
  • State information for security service           modules
That would also cause extra delay when doing failover as the routing protocol would need to re-calculate the routes in order to populate the routing table
Here is the document in case you need it
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#statef
Thanks and I am glad that you were able to solve it.
Cheers.
Mike
