cisco 1941 and hwic-8a configuration
Apr 26th, 2010
hi.
we have old test equipment that has to be configurated using vt-420 terminal.
we used to have cisco AS2511-rj device we use to connect those devices, so that ip-address,port 2001 did go to test device 1 and ip-address, port 2002 did go to test device 2.
after we moved to other building that ancient AS2511-rj did not work anymore.
so we ordered 1941 with HWIC-8a which was recommended to us to replace that old device.
but how should we configure this ?
I did  not found anything from cisco support pages or from google search?
there is no modem between 1941 and test devices, we just want to connect rj-45 to our devices, like we did with old AS2511.
should we use loopback and do like in http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
how should we configure those async interfaces ?
and how is those port numbering connected to async lines ?
is P0 2000 or 2001 ?
shailesh.h Mon, 04/26/2010 - 09:06
  • Bronze, 100 points or more
Hope you have physically installed the card in the router. Kindly share the output of
  1. sh ver (this will show whether u r card is detected or not)
  2. sh running-conf (this will show you the interface details like slot / interface no etc)
Connector types and other misc information is provided in
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/datasheet_c78-491363.html
Asynchronous Serial Task List : To configure an asynchronous interface so you can connect to an asynchronous device on the network, complete the following tasks:
•Specify an Asynchronous Serial Interface
•Configure Asynchronous Serial Encapsulation
•Configure Dedicated or Interactive Mode
•Enable Routing on the Asynchronous Interface
•Configure Group and Member Asynchronous Interfaces
http://www.cisco.com/en/US/docs/ios/11_2/configfun/configuration/guide/1cintrfc.html#wp2580
jakkamikko Tue, 04/27/2010 - 03:02
cisco#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M1, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Dec-09 14:14 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M3, RELEASE SOFTWARE (fc1)
and
cisco#show running-config
Building configuration...
Current configuration : 5649 bytes
! Last configuration change at 11:06:08 UTC Mon Apr 26 2010
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname cisco
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxx
no aaa new-model
no ipv6 cef
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-1193908939
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1193908939
revocation-check none
rsakeypair TP-self-signed-1193908939
crypto pki certificate chain TP-self-signed-1193908939
certificate self-signed 01
  yyy
        quit
license udi pid xxxxx
username xxxxxxxxxxxxx
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_LAN$
ip address aa.aa.aa.74 255.255.255.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Async0/0/0
no ip address
encapsulation slip
interface Async0/0/1
no ip address
encapsulation slip
interface Async0/0/2
no ip address
encapsulation slip
interface Async0/0/3
no ip address
encapsulation slip
interface Async0/0/4
no ip address
encapsulation slip
interface Async0/0/5
no ip address
encapsulation slip
interface Async0/0/6
no ip address
encapsulation slip
interface Async0/0/7
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 aa.aa.aa.1
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
^C
banner login ^C
^C
banner motd ^C
^C
line con 0
login local
line aux 0
line 0/0/0 0/0/7
line vty 0
privilege level 15
login
transport input all
line vty 1 4
privilege level 15
login
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
cisco#
Question is how should I connect those async lines?
using loopback?
or like old AS2511 ?
in there there was no loopback (if old paper copy of running-config is right)
does anyone have similar configuration where I could see basic principle of connecting those lines?
also is port number automatically set?
