USERS FROM LDAP UNABLE TO LOGIN
ericohermoso
I have NAC i added LDAP authentication and i tested from NAC-CAM to LDAP using authentication test and it is successfully authenticated, but if use that users to login in my PC it says invalid username and password.
What maybe the cause of this problem.? Please give advice on this.
thank you.
Faisal Sehbai
Level 7
Level 7
Have you enabled the LDAP auth provider in your Login Pages?
Faisal
Faisal Sehbai
Level 7
Level 7
Faisal
I just enabled it and it working fine using LDAP, I will add auth server using AD SSO, but i am still studying this procedures, This is my first time to add this ADD SSO, can you please advice me if it is advisable, what if the customer is not using LDAP and only use the active directory, What authentication server should i use?
thank you and best regards
