a problem with sticky when the server fails
Apr 26th, 2010
The customer has the following problem. He uses cookie insertion by ACE4710 (ver A3(2.0)). All is working fine, but there is one exception:-( When the client uses VIP, the ACE load-balanced this request and "sticky" the client into server s1 (for example). The client has cookie for s1. But when this server s1 fails, the client will get no web pages - it seems like that ACE has a problem with cookie for the server which is failed. I saw the increasing count of failed connection in the show serverfarm output when the server failed. Please help me.
ciscocsoc Mon, 04/26/2010 - 07:02
  • Silver, 250 points or more
If you add "failaction purge" to the serverfarm definition the ACE will terminate any sessions bound to a failed rserver. The default is to do nothing - "If you do not configure this command, the ACE takes the real server out of rotation for new connections and allows existing connections to complete. The ACE does not send the connections to a backup server in the server farm or to a backup server farm if all servers in the primary server farm fail." (ACE Command Reference).
Cathy
ROMAN TOMASEK Mon, 04/26/2010 - 07:11
Hello Cathy,
thanks for your advice. But the customer doesn't use a backup rserver or a backup serverfarm. He wants to use remaining rservers in the serverfarm:
serverfarm TEST
rserver s1
ins
rserver s2
ins
rserver s3
ins
... - so when the server s1 will fail, the connection for the same user (with cookie for rserver s1) would be load-balanced between remaining servers (s2 and s3). I think that ACE makes it, because I see failed connection for these rservers in the show serverfarm TEST, but the customer doesn't have any output in the browser.
Roman
ciscocsoc Mon, 04/26/2010 - 07:17
Hi Roman,
You don't need a backup server or serverfarm to use the "failaction purge" command.  Users on the failed rserver will have their session terminated and they'll have to restart their connect. This will then bind to one of the remaining active servers. There isn't an easy way to transparently transfer the session. The point of stickiness is that it is used in a situation where the client and the server maintain a state (e.g. the user's authentication), so unless this state information is replicated between the servers "behind the scenes" it doesn't make a lot of sense to fail the session to another rserver.
Cathy
ROMAN TOMASEK Mon, 04/26/2010 - 07:35
Hi Cathy,
I tried to use commands failaction purge and failaction reassign, but the behaviour is same:-( See:
sho serverfarm TEST
serverfarm     : TEST, type: HOST
total rservers : 6
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: s1
       10.254.254.18:0       8      OPERATIONAL  0          1878       68
   rserver: s2
       10.254.254.24:0       8      OUTOFSERVICE 0          409        1
The rserver s2 - it is the server where the client sent first request, for now it is out of service and the failures are increasing for rserver s1.:-(
sho serverfarm TEST detail
total rservers : 6
active rservers: 1
description    : -
state          : ACTIVE
predictor      : LEASTCONNS
   slowstart    : 0 secs
failaction     : PURGE
back-inservice    : 0
partial-threshold : 0
num times failover       : 0
num times back inservice : 0
total conn-dropcount : 0
Probe(s) :
    HTTP,  type = HTTP
    HTTP_443,  type = HTTP
   rserver: s1
       10.254.254.18:0       8      OPERATIONAL  0          1880       68
         max-conns            : -         , out-of-rotation count : -
         min-conns            : -
         conn-rate-limit      : -         , out-of-rotation count : -
         bandwidth-rate-limit : -         , out-of-rotation count : -
         retcode out-of-rotation count : -
   rserver: s2
         min-conns            : -
Related Content
