ACS5.1 join AD okej, but no AD groups is available for selection
MAGNUS SVENSSON
ACS5.1 join AD okej, but no AD groups is available for selection.
Wy is that, if i press the test connection button i get a success.
What am I missing.....
Jagdeep Gambhir
Level 10
Level 10
Hi ,
Please make sure that time and timezone is properly synced on AD and on ACS.
Sync time and timezone---> Clear the AD config on ACS and---> add it back
~JG
Do rate helpful posts
Hi Thanks for your reply.
No I have the same NTP servers for AD and ACS.
BUT
When I try to save the configuration I get this error messages...
Error while configuring Acrive Directory:too many non-option arguments
What am I doing wrong ?????
best regards
Magnus Svensson
Senior Security Consultant
Cygate AB
Röntgenvägen 2,Box 6084,SE-171 06 Solna, Sweden
+46 8 10 878 70 00
+46 8 10 8787 144
+46 76 7626 144
magnus.svensson@cygate.se
www.cygategroup.com<>
MAGNUS SVENSSON
I have now fixed the NTP stuff, AD and my
ACS now uses the same ntp source,
I have used an account with admin privileges, If I puch the test connection button i get a success, BUT  when I try to save the configuration I get this error messages:
Error while configuring Active Directory:too many non-option arguments
What am I doing wrong.....
I was hitting a bug , the admin users had space in the password, once that was changed it starts working
/Magnus.....
