Cisco Unity Express 7.0.5 connection problem to CUCM 6.1
Apr 26th, 2010
Hi all,
I have recently upgraded my  AIM-CUE from version 3.1.1 to version 7.0.5. The upgrade worked fine and i installed new licenses files also. The problem is that when i try to run the initialization wizard i get the following error.
Message from webpage
JTAPI login failed. Error while determining CCM version -1
Do you wish to proceed?
OK   Cancel
If i press ok the system seems to move on but all i get is
Web login failed.
OK
and cannot move one.
I have connectivity with my CUCM and i ve checked all username and passwords.
Any ideas??
