Enabling WAAS SSH from GUI?
aalejo
Level 5
Level 5
This is posible?
As a workaround it is posible to change the file from a backup and restore that file on the WAAS? What file?
Zach Seils
Level 7
Level 7
Alex,
You can enable SSH from the Central Manager GUI under:
Configure > Network > Console Access > SSH
Zach
Hi Zach
WAAS still not registered (or configure to register) in to CM. Any other way?
Hi Alex,
I played around with this a little it, but wasn't able to find a solution.  Looks like you'll need to get console access to the device.
Zach
