IOS to CAT OS
Answered Question
Apr 26th, 2010
Hi All,
Is there any tools avialbe  to convert IOS commands to CAT OS as we have Cisco EDI CatOS to IOS Configuration Conversion Tool?
Jagdev
Correct Answer by rahurao about 6 years 12 months ago
Hi Jagdev,
There are no configuration tools for converting IOS commands to CATOS as the EDI convertor was developed to migrate people from CATOS to IOS as CATOS had been phased out and there are no more bug fixes and updates on CATOS.
The only option which we have to convert the IOS commands to CATOS is through the configuration guide.
Here is one for you reference which is the latest one:
Catalyst 6500 Series Software Configuration  Guide, 8.7
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/acc_list.html
Rahul
Overall Rating: 5 (1 ratings)
Correct Answer
rahurao Sat, 05/01/2010 - 02:43
Hi Jagdev,
Rahul
