Problem: I have two Presence Servers and I want to enable Presence Status and IM communication between them. I have setup Federation, but I am only getting one-way communication. By that I mean, a user associated with Site A can see the presence status of users at Site B and can send them instant messages, which they receive. However, users associates with Site B only see Site A users as off-line and cannot send IM messages, or even reply to IMs sent.
Basic info: Site A is running CUPS 7.0.4.10000-18 and Site B is running CUPS 7.0.6.10000-17. Also, both servers are connected via SIP trunk with the same CUCM cluster.
Here's my Federation setup...
I created a Federated Domain on each server.
Site A:
Domain Name: ci.brooklyn-center.mn.us
Description: Brooklyn Center
Integration Type: Inter-Domain CUP to CUP
Site B:
Domain Name: logis.org
Description: LOGIS
Then I created a Static Route on each server
Site A:
Destination Pattern: .us.mn.brooklyn-center.ci.*
Description: BC Presence Server
Next Hop: IP address of Site B CUPS
Next Hop Port: 5060
Route Type: Domain
Protocol Type: TCP
Priority: 1
Weight: 1
Allow Less-Specific Routes: On
In Service: On
Site B:
Destination Pattern: .org.logis.*
Description: LOGIS Presence
Next Hop: IP address of Site A CUPS
Next Hop Port: 5060
Route Type: Domain
Protocol Type: TCP
Priority: 1
Weight: 1
In Service: On
I configured the Proxy Configuration Setting on each to the following:
Method/Event Routing Status: On
Prefered Proxy Listener: Default Cisco SIP Proxy TCP Listener
Also, Under Presence -> Settings, I checked "Enable Email ID for Federation" on both sides.
There is no firewall between the two Presence Servers and no firewall between the clients I am using for testing.
Question: Can anyone see a problem with my Federation configuration? What trace files should I look at to find the problem?
