SSH from Cisco Router to another Cisco Router
Answered Question
Apr 26th, 2010
I believe I already know what the issue is but wanted to confirm.
I recently changed the configuration of the routers so that all incoming SSH connections can only be done via the specified port:
ip ssh port xxxx rotary 10
created an ACL and everything works beautifully with Putty.  When I try to SSH from a router to another router it sits there and the ACL permits the connection but nothing happens.
I use ssh -p xxxx NAME.
I assume this is because of the cert not being recognized by the connecting router?
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Yes I did.  I tried ssh -l username -p xxxx ipaddress
What is ios version and model name
Ganesh.H
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Tue, 04/27/2010 - 23:56
Ganesh.H
m.kafka Wed, 05/26/2010 - 10:55
I'm afraid you misunderstood the purpose of ip ssh port:
To enable secure access to tty (asynchronous) lines, use the ip ssh port command in global configuration mode. To disable this functionality, use the no form of this command.
ip ssh port por-tnum rotary group
no ip ssh port por-tnum rotary group
The result of your command
is, that incoming ssh sessions destined to your secret port xxxx will be forwarded to a vacant async interface belonging to rotary group 10. That is: anything you type into your ssh client will be sent out as an asynchronous character to the async interface to which the ssh session is connected to. Now I assume that you dont have
What you might want to try is the command rotary which allows to put vty into a rotary group
line vty 2 4
 rotary 10
 login local
Rgds, MiKa
Message was edited by: m.kafka (added line vty rotary)
