Nexux 5010: GLC-T stays down
Apr 26th, 2010
We have a Nexus 5010 on 4.1(3)N2(1) with a GLC-T SFP (1000BaseT) in port 1/1. I've set the speed to 1000 Mbps, the transceiver is recognized but whatever we do, the port remains " down (Link not connected)". Swapping cables or SFPs does not make any result, the link stays down.
According to the datasheet this SFP is supported but we can't get it to work.
Any ideas what could cause it?
Peter
Ethernet1/1 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 0005.9b70.7f88 (bia 0005.9b70.7f88)
  Description: Server Ports GigEth / 10GigEth
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is access
  auto-duplex, 1000 Mb/s, media type is 10g
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  Last link flapped never
  Last clearing of "show interface" counters 00:14:14
  1 minute input rate 0 bits/sec, 0 packets/sec
  1 minute output rate 0 bits/sec, 0 packets/sec
  Rx
    0 input packets 0 unicast packets 0 multicast packets
    0 broadcast packets 0 jumbo packets 0 storm suppression packets
    0 bytes
  Tx
    0 output packets 0 multicast packets
    0 bytes
    0 input error 0 short frame 0 watchdog
    0 no buffer 0 runt 0 CRC 0 ecc
    0 overrun  0 underrun 0 ignored 0 bad etype drop
    0 bad proto drop 0 if down drop 0 input with dribble
    0 input discard
    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
    0 Rx pause 0 Tx pause
  0 interface resets
Overall Rating: 5 (1 ratings)
PETER EIJSBERG Mon, 04/26/2010 - 09:40
Additional info: I found a complaint that calibration is invalid, but I have no idea what that means....
# sh int eth 1/1 transceiver calibrations
Ethernet1/1
    sfp is present
    name is CISCO-FINISAR
    part number is GLC-T
    revision is 8.0
    serial number is MTD610967
    nominal bitrate is 1300 MBits/sec
    cisco id is --
    cisco extended id number is 4
SFP calibration is invalid
Lucien Avramov Mon, 04/26/2010 - 10:50
Ignore at this point the calibration message. I would suggest you to try another GLC-T see if this persists. You may have a bad cable or bad GLC.
PETER EIJSBERG Thu, 04/29/2010 - 09:01
OK, problem solved: it is a hardware compatibility issue: SFPs which work in other switches do not always work in Nexus. Replaced the SFPs with a different version and it works perfectly.
jeffreybunch Mon, 02/28/2011 - 11:07
I know that this thread is older, but since my search is leading me here, I thought I would update. The last reply is invalid. We are talking GLC-T which is not 10Gig. The appropriate matrix is here:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp139256
and the 2232PP clearly supports the GLC-T:
Cisco Nexus 2000 Series
N2K-C2232PP-10GE
GLC-T
GLC-SX-MM
GLC-LH-SM
NX-OS 4.2(1)N2(1)
I have the same issue with the link being down.
vdsudame Wed, 03/02/2011 - 11:15
do you see any information in the logs about the link not coming up? Like transceiver not supported? What does 'show interface' on the 2232 show for that interface in which the SFP is plugged into ? Have you tried 'service unsupported-transceiver' and then removed/reinserted the SFP and has that worked?
vdsudame Wed, 03/02/2011 - 12:34
just wanted clarify... the command service unsupported transceiver is only used as a means to find out if the SFP is supported one or not. We dont recommend customers configure this and get SFP to work in normal working conditions. Its just part of troubleshooting process to find out if the port comes up. If the port does come up with this command then we know there is some issue with that SFP.
hope this clarifies any ligering doubts about the usage of this command.
Lucien Avramov Wed, 03/02/2011 - 12:41
In certain conditions this can help find a specific issue on the SFP, however using this command will have consequences and is not supported for production traffic. The best in such cases is to contact the TAC for further assistance.
jeffreybunch Wed, 03/02/2011 - 12:47
I do have a TAC case open and have replacement GLCs sitting in our remote datacenter. A tech is going to replace them around ~3pm CST. I will update this thread with our findings. (I am having him reseat a GLC I put in service mode first to test). The original GLCs are newly purchased from Cisco, though. Just as an FYI.
jeffreybunch Wed, 03/02/2011 - 13:41
Well, no progress today. Turns out the replacment SFPs are the exact same model that we had and have the same issue. BTW, we tested in the 5020, port 13 as well as the 2232PP. Worked in neither. No logs as to why. Just port notconnected:
Ethernet109/1/32
    transceiver is present
    type is 10Gbase-(unknown)
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4
    revision is
    serial number is AGM150120QF
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
Only log message I received was when the original transceiver was removed. Nothing when put back in.
vdsudame Wed, 03/02/2011 - 14:14
Jeffrey, I see you are already working this issue in TAC Case 616982001. We are currently working on this actively.
Robert Burns Wed, 03/02/2011 - 14:40
Did we notice that he's using 4.1(3)N2(1) and the SFP is supported for NX-OS 4.2(1)N2(1)?
Robert
Luis Perez Fri, 06/15/2012 - 15:42
I am having a similar problem with a SFP-1000BASE-T in my Nexus 5548P port Eth1/18, i have the sfp connected but the lins is always down.
The software version is:
sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2011, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.1(3)N1(1)
  system:    version 5.1(3)N1(1)
  power-seq: Module 1: version v3.0
             Module 2: version v1.0
             Module 3: version v2.0
  uC:        version v1.2.0.1
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1.bin
  kickstart compile time:  12/6/2011 22:00:00 [12/07/2011 06:30:01]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N1.1.bin
  system compile time:     12/6/2011 22:00:00 [12/07/2011 08:09:44]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8263872 kB of memory.
  Processor Board ID FOC15497D49
  Device name: PCHQUIT0203DI01
  bootflash:    2007040 kB
Kernel uptime is 1 day(s), 7 hour(s), 14 minute(s), 20 second(s)
Last reset
  Reason: Unknown
  System version: 5.1(3)N1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
But the outputs for this interface are:
show interface eth1/18 transceiver calibrations
Ethernet1/18
    type is SFP-1000BASE-T
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4B
    revision is 2
    serial number is AGM154123QD
    cisco id is --
Ethernet1/18 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 547f.ee5b.4399 (bia 547f.ee5b.4399)
  Description: HACIA SW-LAN/SAN-TEMPORAL
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 1000 Mb/s, media type is 10G
  EtherType is 0x8100
  Last clearing of "show interface" counters 05:46:39
  30 seconds input rate 0 bits/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
Please help me what is the problem
Carlo Schmidt Fri, 06/15/2012 - 16:54
Luis,
Have you tried:
1) Reseating the SFP
2) Plugged a laptop, or a known working device with a known into the SFP without any patch pannels
3) Try configuring a different port on the Nexus with "speed 1000" and moving the SFP there
4) Test the SFP in another switch?
Carlo
gurpreetabdal Wed, 09/19/2012 - 21:47
My problem was resolved by specifying speed. So, it looks like by default, switch thinks that it need to operate GLC-T in 10G, which it can't. So doing this manual fix of specifying speed helps fix the issue.
N5K# sh int eth1/21 transceiver calibrations
Ethernet1/21
    name is CISCO-METHODE
    part number is SP7041_Rev_F
    revision is F
    serial number is 00000MTC162802H3
    cisco id is --
N5K(config)# int e1/21
DATACORE1(config-if)# speed 1000
DATACORE1(config-if)# shut
DATACORE1(config-if)# no shut
DATACORE1# sh int status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/21       --                 connected 1         full    1000    SFP-1000BAS
Arumuga Raj Sha... Thu, 03/07/2013 - 03:20
I have this same problem as " Ethernet is down Link not connected" in Nexus 7010 Switch.
Since i trying to connect the SFP in one of the Module in N7k. The port is in shutdown mode when i given the command "no shutdown" the LED of the particular port disabled.
GSSO-AGG-N7K-03# sh int eth 7/18
Ethernet7/18 is down (SFP not inserted)
Dedicated Interface
  Hardware: 10000 Ethernet, address: 0026.cbcd.6549 (bia 0026.cbcd.6549)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, auto-speed
  Auto-Negotiation is turned off
  EtherType is 0x8100
  0 interface resets
  RX
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
GSSO-AGG-N7K-03#
Ports  Module-Type                                                 Model              Status
32     10 Gbps Ethernet Module                           N7K-M132XP-12      ok
48     10/100/1000 Mbps Ethernet Module            N7K-M148GT-11      ok
0      Supervisor module-1X                                  N7K-SUP1           active *
0      Supervisor module-1X                                  N7K-SUP1           ha-standby
NXOS  is :
kickstart: version 5.2(5)
system:    version 5.2(5)
In the below link i didnt find the compaitblity of module   M132XP.
Any idea ?
martinreinwein Sat, 03/09/2013 - 19:08
Hi Arumuga,
Did you try to set the speed?
We had issues with the GLC-T SFPs in Nexus-5548 and had to specify "speed 1000" to make it work.
Martin
Leo Laohoo Sat, 03/09/2013 - 19:19
Maybe this is the reason?
Related Content
