Unity Connection - System Call Handler
Apr 26th, 2010
With a System Call Handler there are 0-9 Caller Input Keys. Is there a way to increase this number to 0 - 20 Caller Input Keys?
Jonathan Schulenberg Mon, 04/26/2010 - 10:20
No thankfully. Unity only supports single-digit caller input selections. A 20-option menu would be horrible and unusable anyways.
David Hailey Mon, 04/26/2010 - 10:23
Yes, Jonathan is dead-on.  Ideally, you'd want to try to stay somewhere close to a 4x4 menu structure.  Occassionally it is more or less, but when you try to cram too much into a Call Handler - the end result is usually that callers get annoyed and simply hang up.
Please rate helpful posts!
