Voice over FR changing to Voice over IP
Apr 26th, 2010
I have an existing network with voice over Frame-relay.  The configuration is pt-to-pt 4-wire connectons.
old or existing configuration.
voice-port 3/0/1
non-linear threshold -45
no comfort-noise
timeouts call-disconnect 3
connection trunk 101106301 answer-mode
description FRF.11 Trunk to Lewisville port 2/0/0
operation 4-wire
signal immediate
dial-peer voice 2301 vofr
destination-pattern 101106301
called-number 104101200
session protocol frf11-trunk
session target Serial1/0 21 6
dtmf-relay
codec g726r32
no vad
dial-peer voice 1301 pots
destination-pattern 104101200
port 3/0/1
My question is the NEW dial-peer session protocol what option to chose.
paolo bevilacqua Mon, 04/26/2010 - 11:12
  • Hall of Fame,
    Founding Member
Cisco (h.323) or sipv2. Either should work fine.
CentrepathNCC_2 Mon, 04/26/2010 - 12:17
Ok the Cisco option is a default.  next question is the session target.
Must be of the form     ^((loopback:rtp)|(dns:.*)|(ipv4:[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+(:[0-9]+)?)|(enum:([1-9]|1[0-5]))|(ras)|(sip-server))$
paolo bevilacqua Mon, 04/26/2010 - 12:58
  • Hall of Fame,
    Founding Member
ipv4:
Have you seen a voip config before ? Or trying to do with CLI help ?
