cisco AP 1141n (AIR-AP1141N-A-K9)
Apr 26th, 2010
the AP i have is an AIR-AP1141N-A-K9, which according to cisco is not a controller based, but a standalone AP.  my understanding is that standalone APs do NOT need to work with a controller.  however, i cannot seem to get DHCP and NAT to work on this.
I configured the dhcp pool, but it does not appear to work.  client cannot get an IP address.  if i do a show dot11 association on the AP, i see client's MAC address, but IP address is 0.0.0.0.
i can NOT configure the ip nat inside and ip nat outside and the ip nat inside source at all.  when i input those commands, it keeps telling me "unrecongized command".
below is the config.  how can i make it so that the AP can act as a DHCP server and do NAT for associated wireless clients?
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname Cisco1141-Autonomous
no logging console
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.141.1 192.168.141.99
ip dhcp excluded-address 192.168.50.1 192.168.50.199
ip dhcp pool client
   network 192.168.141.0 255.255.255.0
   dns-server x.x.x.x
   default-router 192.168.141.1
ip dhcp pool Guest
   network 192.168.50.0 255.255.255.0
   dns-server x.x.x.x
   default-router 192.168.50.1
dot11 syslog
dot11 ssid xxxxx
   vlan 2
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 xxxxx
dot11 ssid yyyyy
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 yyyyy
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm tkip
encryption vlan 1 mode ciphers aes-ccm tkip
ssid xxxxx
ssid yyyyy
antenna gain 0
mbssid
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
ip address x.x.x.x 255.255.255.128
no ip route-cache
duplex auto
speed auto
no keepalive
no cdp enable
interface BVI1
ip address 192.168.141.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface BVI2
ip address 192.168.50.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip default-gateway x.x.x.x
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
no cdp run
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 15 0
line vty 0 4
access-class 111 in
exec-timeout 15 0
line vty 5 15
access-class 111 in
exec-timeout 15 0
sntp broadcast client
end
Overall Rating: 5 (1 ratings)
tachyon05 Mon, 04/26/2010 - 11:17
ok.  Does that mean that I still need a controller/router to work with this standalone AP (to provide dhcp and NAT)?
if NAT is not supported on this standalone AP, what are the advantages of getting a standalone AP (vs. a controller based AP)?
Kayle Miller Mon, 04/26/2010 - 11:25
Tachyon05,
     To my knowledge NAT is not supported with-in the controller either; you'd still need a router or firewall to do the NAT.
In terms of advantage of aIOS (Standalone) -vs- LWAPP (Controller based) there are pros and cons for both and each person will argue it to a different bias. For a small deployment a controller based system can be extremely cost prohibitive since the controllers are expensive.
     Hope this helps.
tachyon05 Mon, 04/26/2010 - 11:29
ok, i guess i must have misunderstood what they mean by standalone.  thanks for your help.
Kayle Miller Mon, 04/26/2010 - 11:52
Tachyon05,
     Maybe I can clarify this information for you since you are correct you may have misunderstood what Cisco means by standalone.
aIOS (Stand-alone AP, ex: AIR-AP1242AG-x-K9, AIR-AP1131AG-x-K9)
     This is a stand-alone cisco access point running IOS software, all configuration is performed and stored on the access point and it operates independent of other access points or devices. Each IOS ap is it's own entitiy/device. To install a new aIOS ap you must apply a configuration to it manually and it's unaware of the other access points around it.
LWAPP (Controller based access points, ex: AIR-LAP1242AG-x-K9, AIR-LAP1131AG-x-K9)
     This is a controller based cisco access point, all configuration is performed and stored on the Wireless Lan Controller any access point that connects to this controller will inherit the same configuration as the others. In an LWAPP system the AP's are more aware of the AP's near them, there are alot of advanced fatures that exist on the controller based that the aIOS doesn't support. Also when you power off an LWAPP AP it loses all of it's config and retains almost no data about your network, unlike the aIOS AP.. An LWAPP  AP gets a new configuration each time it connects to it's controller.
Hope this helps clarify it for you..
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
