ACE Health probe using get URL
Answered Question
Apr 26th, 2010
We are trying to create a health probe for our google search appliances and as part of the URL get there is a question mark but the ACE doesn't like that.  Is there a way around this or should it be done differently?
request method get url /searchq? (This is what we want the URL to be)
request method get url /searchq (This is where it thinks i'm asking it for help)
Thanks in Advance.
Correct Answer by Sean Merrow about 6 years 8 months ago
You need to typ CRTL+v prior to entering the ?
That's the Control key then lowercase v, then your question mark.
Hope this helps,
Sean
Overall Rating: 5 (1 ratings)
Correct Answer
Sean Merrow Mon, 04/26/2010 - 11:00
Hope this helps,
Sean
