NAC CAS HA Pair issue
Kristen Sims
I had to rebuild the primary CAS. I have both up and running and was configuring the HA on the rebuilt CAS.
Scenario is CAS17 (primary that was rebuilt) shows OK [ACTIVE]   Peer Server (CAS18) OK
CAS18 shows OK ACTIVE         Peer Server (CAS17) DEAD
*note- I have not plugged in my untrusted interfaces yet.
Faisal Sehbai
Level 7
Level 7
Kristen,
If you're on 4.7.x, check your certs. Make sure both the CASs have the same certs installed on them.
Faisal
Currently on 4.5.1. When I rebuilt CAS17, I imported the certs. Certs look the same on both.
I just fixed the issue. There was an issue with the rebuilt's hostname. It looked right, but obviously
wasn't. When I copy pasted it from the standby to it and rebooted both. They came online like they should.
Thanks for your suggestion.
