interactive password prompt for 2950 when SSH is enable
Apr 26th, 2010
Hi !
we had recently deployed AAA authentication on our network for administrative session on our telecom devices...  We have mixed plate-form telecom device.  We notice with 2950 when the SSH is enable it's not possible to receiving different prompt password base on if AAA server is responding or not, like it is possible with all other plate-form.
Exemple : with 2960 Catalyst switch if ACS server responding my prompt password will be : "ACS Password" like I had requested in the ACS server configuration, if RSA token authentication is requiered for my 2960 "PASSCODE" is the prompt password....  For my 250 catalyst it is always "password" as prompt password.
If I disable SSH on 2950 switch, interactive password is workling correctly like it is with older switch plate-form like Catalyst 1900, 2924, 1720 router.... etc....
is any possible way to enable interactive password on 2950 switch plate-form, when SSH is used ?
Thanks a lot !
