BGP 4-Byte AS Number
Answered Question
Apr 26th, 2010
recently i got my AS number 196921. But in Router when ever i issue the command: router bgp?--> it shows only 1-65535.
Can someone suggest me how to enable this AS number 196921 to my Router?
The IOS that i am using it supports 4-Byte AS number.
Rgds,
Partha
Correct Answer by csawest.dc about 6 years 10 months ago
Dear Friend,
Pl see :
http://as4.nullroute.se/index.php
Cheers!!!
Vaib...
Dear Friend,
U need to configred 4 byte ASN in doted
Your BGP : 196921 is in plain notation, converting to asdot:
ASN: 3.313
router bgp 3.313
Cheers!!!
Vaib...
Overall Rating: 5 (2 ratings)
lamav Mon, 04/26/2010 - 15:18
What model router and what version of IOS are you running?
Victor
Giuseppe Larosa Tue, 04/27/2010 - 01:03
Hello Partha,
according to cisco feature navigator BGP 4 byte AS number should be supported on several 12.2(33)SRE1 IOS images if you have a sup720 or an RSP 720 or a Sup 32
http://www.cisco.com/go/fn
search by feature : BGP support for 4-byte ASN
so your question is wise
the configuration may need to use a dotted notation like
router bgp x.y
so you need to calculate x and y so that x*65536 + y = ASN
this is called AS DOT notation
see
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6554/ps6599/4byte_asnios.pdf
Hope to help
Giuseppe
Correct Answer
csawest.dc Tue, 04/27/2010 - 06:49
Dear Friend,
ASN: 3.313
router bgp 3.313
Cheers!!!
Vaib...
acharyr123 Tue, 04/27/2010 - 08:01
So you mean to say that, As plain format is not going to work??
Rgds,
Partha
